Re: 93 Accord Engine Problem
When was the last time you changed the timing belt and how many miles on the car? Take the oil filler cap off and while you are looking inside the valve cover, have somebody crank the engine. If the camshaft turns, your timing belt is probably OK. Then see if you have spark when you turn the engine over. If not, then there are a bunch of tests that need to be done to troubleshoot the problem.
