Water is leaking into my car somehow. I think it might be from underneath, but not totally sure. Just on drivers side. Whenever it rains, the floor is really wet under the floormat in the front and back, but not underneath the seat. Has anyone else had this problem on the avenger or any other car????
I have not had this problem or heard of anyone else with it. Sounds to me like you need to look under the drivers side of the car. See if the underside floor pan is rusted through. Then water would get in onto the carpet. Not much you can do to fix that other than to have some metal plate welded in and the rust cut out if thats the case. If it is a small hole you might be able to get away with some body sealer.
Sweet, thanks, I'll check it out when it stops raining, be nice to know whats causing it :o).
