Hicas HELPPPPP!!!!miguelcolmenero 06-11-2002, 08:39 PM :( this has probably been answered here before but i couldn't find it....so, what does it mean when after 30 min of driving the HICAS light comes on? i can shut off the car and restart it, drive another 30 min and it comes right back on. do i need a new HICAS computer or what?any help would be greatly appreciated cause this is bugging the crap out of me. I'll already checked the power steering fluid an is ok PLease Help ASAP thanks in advance> Miguel Colmenero ronin3 07-02-2002, 07:37 AM I recently had the same problem with my R32 GTS-T Type M. My speedometer/odometer stopped moving and the problem started. About a half hour of driving, then power steering goes and HICAS light come on. Restart the car, and things are okay for a while again. Just fixed the meters, I hope it was related and won't recur. Please help if you know! ncu17 01-17-2005, 12:23 PM I recently had the same problem with my R32 GTS-T Type M. My speedometer/odometer stopped moving and the problem started. About a half hour of driving, then power steering goes and HICAS light come on. Restart the car, and things are okay for a while again. Just fixed the meters, I hope it was related and won't recur. Please help if you know! Hi, Any response from anyone on this issue? ronin3 01-17-2005, 01:03 PM When the speedometer was fixed, the problem went away. Probably related to the speed sensor. Miss that car... sadaukar 01-30-2005, 11:45 PM can also be that your battery is getting old. computer controlled cars demand correct voltages. i had a problem with mine and a new battery fixed everything GTRdriver 02-05-2005, 03:47 AM Have you checked you Power Steering Fluid. I had a similar problem. I was told by somebody else to check my fluid. When I added more fluid, the light stayed off. If you already checked that, then I am as lost as you. HypeR33 02-07-2005, 04:11 AM I have a similar problem with my 33 GTS-T. Do you by any chance have an aftermarket steering wheel? This has been discussed on other skyline forums as being the cause of the problem, with the steering wheel not lined up with the sensor properly. Something for you to check out if you have an aftermarket wheel. Automotive Network, Inc., Copyright ©2012
