Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-09-2006, 07:52 AM   #1
vapoorboys
vapoorboys Normal reputation
Question 1997 Camry cv axle
1997 Toyota Camry LE 4 cyl Auto, passanger side CV axle. We have the axle away from the hub, have pulled the snap ring and intermediate shaft bearing lock nut, have tried to pull the shaft out but it won't come. We haven't tried a big pry bar yet wanted to ask for suggestions? Help.. Thanks!
vapoorboys is offline   Reply With Quote
Old 01-09-2006, 12:22 PM   #2
Daniel M. Dreifus
AF -Advisor
Daniel M. Dreifus Normal reputation
Re: 1997 Camry cv axle
carrier bearing is probably binding in the housing - try Kroil or other rust penetrant, then try pulling again.
Some bozo reused the old carrier bearing lock bolt with the neoprene tip missing on mine, so the carrier bearing had been rotating in the cast iron housing giving it no opportunity to rust in place. As a result, I was prepared for some heavy pulling, but the axle just fell out in my hands - that's why I think yours must be binding there.
Daniel M. Dreifus is offline   Reply With Quote
Old 01-09-2006, 01:05 PM   #3
Toysrme
AF - Advisor
Toysrme's Avatar
Toysrme Normal reputation
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool
Like Daniel told you, lubricated it & try.
Then use a sledge, or pry bar. Happens every time. Nothing to worry about.
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
Toysrme is offline   Reply With Quote
Old 01-10-2006, 09:05 AM   #4
vapoorboys
Axle
Well a large punch and a BFH seems to do the trick, it wasn't easy but after a beer or two afterwards it was all FUN.... Thanks for the Moral support...
Bookmarks
Google
Web AF
