Re: Easiest way to strip a truck
Are you talking about taking it down to baremetal? I actually use a combination of methods, depending on what I am stripping. For large exterior panels, the way I like best is to use my 8 inch orbital sander, with 36 and when most of the paint is off, switch to 80 grit on a 6 inch da to take off remaining paint as well as smooth out the 36 grit scratches. other times, for some areas I will use paint stripper. Brush it on thick in one direction only and let it sit. May take a few applications and a little sanding to get it all off. Make sure you neutralize it when you are done, cleaning well if there are any cracks or anything it could have seeped in. You do not want it coming back later after its painted and ruining the paint there. I am not a fan of stripper because I think its messy. Then somethings I will carefully sandblast, but be carefull. You can ruin good sheetmetal if you are not carefull with a sandblaster. Stuff like door hinges, and some spots its just easiest to blast. And other times, hand sanding. Maybe try different methods and see what works best for you. And you may want to break up the work, a panel or two at a time. Then you won't get so overwhelmed, and if the metal is clean and rust free, shoot some epoxy primer on the stripped part to keep the metal from possibly flash rusting sitting in the open too long. If you do get any flash rust on the surface at all, apply a metal prep solution or self etching primer before the epoxy primer. Make sure you read the product sheets for the primer you are using, it will tell you correct mixing and use, and give any precautions.
Victorylap.20fr.com
