Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-08-2006, 04:38 PM   #1
jackjack
jackjack Normal reputation
1999 Camry CE Radio Swap
I have swapped out original Toyota Casset player with a Sony CD Player with removable face plate. I can get the unit to reset but the unit does not seem to turn on.
Any help
jackjack is offline   Reply With Quote
Old 01-09-2006, 12:17 AM   #2
InstallTech
InstallTech's Avatar
InstallTech Normal reputation
Re: 1999 Camry CE Radio Swap
You lost your ignition power source. It still has constant power, being that you can reset but not turn the unit on. You need both 12 v constant and an ignition source for the unit to power up. Check your fuses. There should be one for radio either inside the vehicle or under the hood. If that's not it, check for a fuse either on the radio wiring itself, or on the back of the radio. If *that* doesn't work, then you may have a faulty radio.
I reject your reality, and substitute it with my own.
InstallTech is offline   Reply With Quote
Old 01-09-2006, 08:35 PM   #3
AccordCodger
AccordCodger Normal reputation
Or - of course - you didn't wire it up correctly.
AccordCodger is offline   Reply With Quote
Bookmarks
Google
Web AF
