Abs Light OnTootz 01-08-2006, 02:45 PM Had a wheel speed sensor bad on 95 Aurora had it replaced, and the traction and abs light is still on. any ideas on what to do next?? I thought the lights would go off , but it didnt. Reset the computer again but brakes still lock up just before stopping. Help!!!! maxwedge 01-08-2006, 03:51 PM Get it scanned on an abs functional scanner and look at comparative wheel speeds under 8 mph, you should see a sensor drop out before the others. mcnu 01-16-2006, 11:43 AM i have a 97 and the same thing happened to me. It is more than likely that the wire harness for the sensor is bad. Once you replace that, your abs and traction should work and the light will go off. I have not replaced it yet, as i just cant see spending the money. good luck Automotive Network, Inc., Copyright ©2012
