Jammed sliding door loc
guitarde
01-08-2006, 10:33 AM
Hi,
I have a 1999 Windstar LX, the sliding door on the driver side is jammed.
This is a manual door, it opens about 1 inche and is blocked.
Seems like the lock on the rear of the door is jammed.
What is the best wat to fix this ?
Thanks for your help.
Eric
frostie
01-08-2006, 01:55 PM
Have you checked the gas filler door? It is interlocked so that the door cannot open when the filler door is open.
guitarde
01-09-2006, 01:51 PM
This sounds like a better cause since the door opens by about 1 inche, if the lock allow the door to open like that it could be dangerous.
The fille door is closed correctly, maybe there is a problem with the mechanism and this block the door.
Do this block the door on the back railing ?
Where /how can I see this interlocked mechanism ?
Thanks again
Eric
frostie
01-10-2006, 05:58 PM
IIRC, if you look on the body between the fuel filler door and the opening for the sliding door. You will see a latch. Peel back the rubber weatherstripping and you should be able to see inside.
The latch might just be stuck. Good luck.
