Engine Control Fuse Keeps Blowing
chad303
01-07-2006, 05:46 PM
I recently checked my fuse box due to my car not starting and found that the engine control fuse had blown, so i got a new one and as soon as i put it in and turned the key the fuse blew. I have replaced it several times to be sure but I still get the same result. I believe there is a short in one of the wires but I am not sure. If anybody knows anyway to fix this or what to check please responed as soon as possible.
Saudade
01-07-2006, 08:45 PM
Which key position? On, Start, Acc?
You can find some schematics here.
http://www1.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/15/3e/8f/0900823d80153e8f.jsp
Scoll down the list to find your year.
Dale Aeppli
01-09-2006, 03:55 PM
Check the wiring going down to o.2 sensor and the crankshaft position sensor on bellhousing. Especally around the exhaust manifolds. They get burnt from manifolds. Dale :2cents:
liobaj
01-10-2006, 02:20 PM
I had the same problem a couple of months ago. My mechanic had to check all the wires associated with the Eng. Ctrl fuse. He found a defective wire that was causing a short. I believe he told me it was a black and green wire. Good luck!
