Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Pontiac > Grand Prix
Old 01-07-2006, 06:01 AM   #1
smetzler
smetzler Normal reputation
Question Blower Fan works on setting 3-4-5, but not 1-2
I have a 2003 Pontiac Grand Prix GT. I recently replaced the Heater/AC Control unit (dual temp, not digital) twice. First time I replaced it was due to the air flow not changing (vent to floor, etc.) and the AC light (on/off) not working. It has been working fine until now.
This time I changing the unit due to the fact when I turn the bower on 1 or 2, nothing happens - no air. I tried both the new unit and the old unit. Blower on 3-4-5 work fine and everything else (air flow, A/C) seems to work fine. Neither unit works with the blower at 1-2.
Any ideas, suggestions would be helpful.
Thanks
Sahwn
smetzler is offline   Reply With Quote
Old 01-07-2006, 08:13 AM   #2
BNaylor
BNaylor's Avatar
BNaylor +50
Re: Blower Fan works on setting 3-4-5, but not 1-2
How about the blower motor resistor? Have you replaced it?
'08 Pontiac Grand Prix GXP - LS4 5.3L V8
'01 Buick Regal GS - L67 Series II 3800 V6 Supercharged
'97 Pontiac Grand Prix GTP - L67 Series II 3800 V6 Supercharged
Timeslip 08/12/06
AF Community Guidelines
BNaylor is offline   Reply With Quote
Old 01-07-2006, 11:05 AM   #3
smetzler
Thanks, but I'm new to this and learning as I go along. Where would I found the blower motor resistor?
Shawn
Old 01-07-2006, 11:14 AM   #4
BNaylor
BNaylor's Avatar
BNaylor +50
Shawn
Checkout the link below. It shows the location of the BMR and R&R procedure.
http://www.clubgp.com/newforum/tm.as...4510857&cookie
BMR costs from $25 - $50 depending on where you get it. Autozone has Wells brand for around $25.00 which is similar to the improved GM version. Good luck!
Timeslip 08/12/06
Old 01-07-2006, 01:34 PM   #5
smetzler
Cool. Thanks a bunch.
Old 01-08-2006, 06:02 PM   #6
smetzler
Talking
Lets see. Two - three hours of my time, $5 for the replacement pins and $24 for the blower motor resistor. I don't know how much you saved me, but I'm sure its hundreds. Thank you vey much !!!
By the way, the third screw in the back - how do you loosen it? Luckily I was able to work out the old blower motor resistor and basically just use the two screws to hold it is which is more than enough.
Thanks again
Shawn
Bookmarks
Google
Web AF
