Hign Idle
MyNeoN95
01-05-2006, 09:07 PM
95 SOHC 2.0L
When starting the NEON, it starts up with a VERY HIGH IDLE then goes down to normal idle. Is that normal or is there a issue. NO check engine light.THANKS
das2123
01-06-2006, 08:46 AM
95 SOHC 2.0L
When starting the NEON, it starts up with a VERY HIGH IDLE then goes down to normal idle. Is that normal or is there a issue. NO check engine light.THANKSCould be your TPS acting up on you.
MyNeoN95
01-06-2006, 08:59 AM
Wheres the TPS located, and can It be changed with a new one. Thanks for your reply.
das2123
01-06-2006, 12:49 PM
Wheres the TPS located, and can It be changed with a new one. Thanks for your reply.It should be mounted on the driver side of the throttle body. Yes you can change it. Runs about $50 from auto parts stores.
