broken bolt on thermostat housinglilaroe 01-05-2006, 02:37 PM I was replacing my thermostat and one of the thermostat housing bolt heads snapped off on my ratchet! I'm left with about 1/4 inch of thread. I've tried channel locks and vice grips...to no avail. Does anybody have any ideas? I swear I'm cursed when it comes to this car! dougand3 01-05-2006, 04:46 PM I did the exact same thing. I tried a drill out extractor - it broke off in the bolt. What I did was tap threads in the block...#8 or 10 or 12 size bolt (can't remember)...right beside the original bolt hole. I adapted the housing with a new bolt hole to match the tapped threads. Use a gasket and permatex on both sides of gasket. See the keyhole on bottom left of my housing - right side of it is the new bolt hole. http://home.comcast.net/~dougand3/tstathousing1b1.jpg KimMG 01-05-2006, 11:57 PM Soak the broken bolt/stud with PB Blaster or some other penetrating oil for a day or two. If you can get a grip on the bolt with vise grips, try tightening the bolt to break it free, about 1/32 of a turn or less (before loosening). Otherwise you are going to have to drill it out. When putting in new bolts, use anti-sieze compound on the threads. Davescort97 01-06-2006, 03:46 AM If you can get on it with vise-grips try tapping the vise grips with a small hammer rather than trying to torque it out. A series of small taps rather than trying to twist it out is the key. I'm afraid a strong steady pull will just break off what you have left. Then you'll have to drill it out. onebrucelee 01-08-2006, 10:44 AM Hi soak area with seafoam penatrating spray, Take torch heat around broken bolt, now this spray can be used on heat great stuff spray after heated use a very good pair of vise grips as you turn spray a little more, working the bolt i found helps also so while turn this broken piece out you can go in and out this allows the seafoam to coat threads so you don't chance a helicoil. Automotive Network, Inc., Copyright ©2012
