ram brakeshondahappy86 01-04-2006, 06:30 PM i have a 1997 dodge ram 1500 2wd with rear antilock brakes only....if anybody has the same setup then tell me....ive been to autozone and advance auto parts and they only show the front rotors for rams with 4 wheel abs.....but not for rear wheel abs....and for rear wheel abs.....the abs sensor ring causes some clearance issues and ram 150 van with rear only abs has a totally diffrent sized hub.......my question is....what the hell....its like to places like theese the rear wheel abs dosent exsist scoutinkeith 01-05-2006, 04:26 PM I found these part numbers for front break rotors for a 97 2wd 1500 ram on the autozone website, might try giving the guy at the counter the number and see if they can come up with something. Duralast 5357 $96.99 each with a 2 year waranty Valuecraft 5357B $47.99 each with 1yr warranty Baer 5357-020 $282.99 each with 3yr waranty hondahappy86 01-06-2006, 01:40 AM 5357 is the brake rotor for the 4 wheel antilock.....ive checked allready....thanks for the help tho...... scoutinkeith 01-11-2006, 11:15 AM I did a little more looking around, and all the info that I've found says that the rotors should be the same for ABS, and non ABS. all the info that I found said that the ABS stuff (tone ring/sensor) should be on the uni-hub, and not cause any interferance with the rotors. Automotive Network, Inc., Copyright ©2012
