1997 Ram Ignition Start ProblemKeep It Cowboy 01-04-2006, 01:40 PM The 40 amp "Ignition Run" fuse in the power control box, of my 1997 Dodge Ram 2500, 5.9 litre turbo Cummins, burns out when I turn the ignition to "start." 'Took out the ignition switch, tested it, and found it to be fine. 'Purchased a new ignition switch and installed it, just to make sure, and the same thing happened. ‘Tested clutch pedal switch and it is fine. ‘Jumped battery to starter motor and it turned over. Fuel shut down solenoid also appears to be okay. ‘Wiring harness appears to be in good shape. Has anyone got any idea of what may be causing the problem. The local Dodge dealer hasn't been of much help. joh9356 01-04-2006, 04:21 PM The 40 amp "Ignition Run" fuse in the power control box, of my 1997 Dodge Ram 2500, 5.9 litre turbo Cummins, burns out when I turn the ignition to "start." 'Took out the ignition switch, tested it, and found it to be fine. 'Purchased a new ignition switch and installed it, just to make sure, and the same thing happened. ‘Tested clutch pedal switch and it is fine. ‘Jumped battery to starter motor and it turned over. Fuel shut down solenoid also appears to be okay. ‘Wiring harness appears to be in good shape. Has anyone got any idea of what may be causing the problem. The local Dodge dealer hasn't been of much help. Did you add any accessories to this truck recently such as a towing package or anything else? It looks like somethign was incorrectly installed on the ignition-on circuit and shorting it out. If all above is ok, then I would disconnect that battery and start tracing the continuity to ground with an ohmmeter through that same circuit. game42 01-04-2006, 06:05 PM I don't have the answer to your problem, but I have saved hundreds of dollars by joining Turbodiesel.com and paying my $35 for a years worth of information. mustang1965 02-01-2006, 04:23 PM The 40 amp "Ignition Run" fuse in the power control box, of my 1997 Dodge Ram 2500, 5.9 litre turbo Cummins, burns out when I turn the ignition to "start." 'Took out the ignition switch, tested it, and found it to be fine. 'Purchased a new ignition switch and installed it, just to make sure, and the same thing happened. ‘Tested clutch pedal switch and it is fine. ‘Jumped battery to starter motor and it turned over. Fuel shut down solenoid also appears to be okay. ‘Wiring harness appears to be in good shape. Has anyone got any idea of what may be causing the problem. The local Dodge dealer hasn't been of much help. do you know where fuel shutdown relay is thanks mustang1965 02-01-2006, 04:28 PM hi i have a 94 dodge ram 5.2 L has no spark from coil replaced crank sencor no luck new wires cap relays in fuse box sombody said if no fuel pressur there will be no spark is that true is there a fuel switch or solinode i can check iven changed comp no luck very hard on for you all thanks and is there anywhere i can get a wiring digrame on line for free Automotive Network, Inc., Copyright ©2012
