Camshaft Position Sensor
Google
Web AF
crys36
01-04-2006, 12:25 AM
when I ordered the Crank Sensor from Jeep $77, I also inquired as to the where and why for a Cam Pos Sensor. He told me that the Sensor is located in the oil pump drive gears that also have a shear pin in them . He also stated that these sensors go bad just as much as anything else on the Jeep. Also that the shear pins break enough times causing the sensor not to turn so to look for that also. He sells alot of both. I was pretty sure he said location on -Oil Pump Drive-- I was like freakin what-where--I kept the sensor anyway -might as well replace that 2 while I'm at it. I told him we will be talking quite often to which he agreed. Real nice guy. So is this true where the Cam Sensor is or did I hear him wrong. You guys have been great and I hope to have this baby firing up in the next 24hrs .. PLEASE --I;ve paid my dues. Just 1 little sputter and I'll be happy--Chris
Dale Aeppli
01-04-2006, 10:44 AM
CAMSHAFT POSITION SENSOR---- 4.0 ENGINE
The camshaft position sensor ( CMP) on the 4.0 6- cylinder is bolted to the top of the oil pump drive shaft assembly. The sensor and drive shaft assembly is located on the right side of engine near the oil filter. The rotational position of oil pump drive determines fuel synchronizational ONLY. It does not determine ignition timing.
DO NOT ATTEMPT TO ROTATE THE OIL PUMP DRIVE TO MODIFY IGNITION TIMING. The ( CMP ) replaces the distributor assembly starting in year 2000. jeepman600#sbcglobal.net
Dale :grinyes:
crys36
01-04-2006, 11:23 AM
Thanks Dale I knew it had to do with the fuel timing but had no idea where it would go. He said where the distributor used to be but your answer was on-time and just what the doctor ordered. Thanks again. Could'nt be even trying all these things without you guys.---Chris :cool:
Dale Aeppli
01-04-2006, 02:13 PM
INSTALLATION----SENSOR ONLY
1---Install sensor to oil pump drive
2---I nstall the 2 sensor mounting bolts and tighten to 2N-m (15 ins. lbs.) torque
3--- Connect electrical connector to CMP sensor
If you need instructions on installing ( OIL PUMP DRIVE ASSEMBLY ) HOLLER Dale jeepman600@sbcglobal.net :2cents:
crys36
01-04-2006, 02:59 PM
Thanks Dale don't know what I'd do without ya. I'm in the process of installing The Crank Sensor --Cleaning the other side with contact cleaner and a toothbrush- a little very fine emory cloth and another spray and brush. Just picked some dilectric grease for the coupling then I'll tackle The Cam Sensor--Again thanks Soooo Much and If I have 2 I'll mail you. Can't have enough info on these things---Chris
Google
Web AF
