removing the center consol
fastlane1588
01-03-2006, 09:28 PM
I have a 98 auto cavy and I attempted to remove my consol today but i could only get the back half undone, does anyone know how to remove the center consol? thanks.
Cavalier2000
01-04-2006, 01:28 PM
there should be two screws in teh center itself did you take them out?
fastlane1588
01-04-2006, 01:40 PM
yea, i took out the two screws in the back half of the consol, then i poped up the plastic section around the shifter, and in there there was a nother screw i took out, and everything was free except the front part, by the tray/cup holder, that section seemed to still be attatched
Cavalier2000
01-04-2006, 04:31 PM
yea there is a screw there as well it is hidden under a cover. If you look good enough in teh fron you will be able to see some a cut out. Just take a small flat tip and pry out the cover and you will see the screw. there is also one under the compartment hole thing or were your window switch would be if you have power windows.
1 In front
1 Middle
2 Back.
I think that is all of them anyway let me know if you have any more probelms.
Also when you go to take it out watch out of the e-brake. You have to move around it enough to get the center out from it sheeth. then put the e-brake down and it will come righ tout
fastlane1588
01-04-2006, 08:29 PM
thanks, i found it, in the tray there was a little cover tha came right off and under it was the screw! thanks for you help
Cavalier2000
01-04-2006, 10:32 PM
no problem
