Key Fob Programmingchobes 01-03-2006, 09:20 AM Can anyone help with programming a key fob. Purchased a 2000 Cherokee sport that has keyless entry but no Key fob. I have a new key fob for the vehicle now and need to program the vehicle to recognize the new fob. Anyone know how to do this??? I know that it can be done on a GM, but can it be done on a Jeep? Thanks, Chobes oljeeptek 01-04-2006, 12:01 AM Have you tried simultaneously pressing and holding the "lock" and "unlock" buttons on the FOB for 15 seconds? tch1717 01-07-2006, 04:27 PM Can anyone help with programming a key fob. Purchased a 2000 Cherokee sport that has keyless entry but no Key fob. I have a new key fob for the vehicle now and need to program the vehicle to recognize the new fob. Anyone know how to do this??? I know that it can be done on a GM, but can it be done on a Jeep? Thanks, Chobes hey chobes : i can tell you that with your key fob on your 2000 cherokee that you have to go to a chrysler/jeep dealer so they can program the fobs with there DRBIII (chrysler scanner), i know this because i am a mechanic at a chrysler dealer, hope this helps you out, good luck chobes 01-08-2006, 01:51 AM hey chobes : i can tell you that with your key fob on your 2000 cherokee that you have to go to a chrysler/jeep dealer so they can program the fobs with there DRBIII (chrysler scanner), i know this because i am a mechanic at a chrysler dealer, hope this helps you out, good luck Thanks tch1717, That is probably going to cost quite a bit ah! chobes tch1717 01-08-2006, 11:21 AM Thanks tch1717, That is probably going to cost quite a bit ah! chobes nah they shouldn't charge you to much $20-$30 maybe, they may not charge anything (depending on how good of a mood they are in at the time), it only takes aboiut 5 minutes to do it. sklater 01-09-2006, 04:17 PM nah they shouldn't charge you to much $20-$30 maybe, they may not charge anything (depending on how good of a mood they are in at the time), it only takes aboiut 5 minutes to do it. Just make sure that when they program the remote at the dealership, which is the only way to do it on newer jeeps, that they look up under their program thingamajig, they instead of looking up under keys or entry, they need to look under alarm system or something very similiar to that, or they will not be able to program it. chobes 01-09-2006, 10:11 PM Thanks sklater. I will check into that. chobes Automotive Network, Inc., Copyright ©2012
