Changing fluids
ColoradoSilverado
01-02-2006, 11:49 PM
I want to go ahead and change the fluids in Rear and front differential and the transfer case, what kind of oil to use ? For the engine and tranny I use Valvoline.
http://tinypic.com/jkhhlf.jpg
nineball481
01-03-2006, 10:25 AM
I've used Valvoline GEAR OIL before and had no problems. I'm sure you probably know, but I feel compelled to say anyway.....
Do not use regular oil in the differential, It is way to thin.....Any auto store will carry gear oil....
ColoradoSilverado
01-06-2006, 04:11 PM
I found out I can use Valvoline 75W90 Gear Oil for both front and rear differential but what do I use in the transfer case ?
FiTxAg04
01-06-2006, 10:36 PM
If you have Autotrac 4x4 I would highly recommend GMs fluid specifically for that (available from the dealer). If you have a floor shifter, I have no idea... I would enlist the help of the owner's manual (assuming you still have it) or ask the dealer what to use.
ColoradoSilverado
01-07-2006, 09:02 AM
Anyone know how to find out what rear differential i have ?
tykrz
01-07-2006, 11:47 AM
RPO code in glove box
horse482
01-07-2006, 01:23 PM
I would use Royal Purple. You can go to www.royalpurple.com to find a dealer closest to you. It is an excelent oil. A little pricey but worth it.
jers99z
01-08-2006, 01:47 AM
I have to agree with horse, when i do mine im going with royal purple, im just trying to find somewhere that carries it. Ive seen dyno tests done to where the trucks performace increased after all the fluids had been changed.
ColoradoSilverado
01-10-2006, 12:39 AM
What is this PRO code ? Only thing I see is the vin# Is there a way to see by looking at my rear axle to see wich one it is ? Only need toknow how much gear oil I need.
robjen
01-10-2006, 07:54 AM
I put amsoil in mine, and it seems to be doing ok. As for the transfercase, if you have the autotrac, automatic 4x4 button on the dash then you have to use the blue fluid from gm, its expensive.
I used Severgear 75 -80w in front, and 75-140w in the rear. I wish I would have just used the lighter stuff in both. I think it was $9 a quart.
robjen
01-10-2006, 07:57 AM
Here is a site that you can look up the types of oil.
http://www.amsoil.com/scripts/runisa.dll?amsoiloaf:index
also I don't sell the product, I just use it. I have had very good results with it.
