How to remove tint
OZBIRN454
01-02-2006, 09:37 PM
I just bought a used 96 with dark as hell tind on door glass and I want to remove it. Is there any good way to do this? Do I need some kind of remover? Thanks Jim
97cavalier
01-03-2006, 12:05 AM
Does it have any bubles in it? if so it will be real easy, if not it is not to hard to do, it is just all the glue after that is a pain. Here is wht u do go get some foam glass cleaner and a sharp razer blade, be carful with the blade that u don't scratch window. Open door and start at the top and get under the tint with blade and scrape off. It takes a while to get it off. After u get it all off, spray the whole window with the foam and take blade and scrape all th glue off. You will have to wipe the window a copple times with a towl because all the glue.
Tdragone
01-03-2006, 01:11 AM
I know with the older tints you're not supposed yo use certain window cleaners beause they use either ammonia or alcohol; I don't remember which.
Maybe someone else can hel on which it is; that way your tint will get the bubbles and be easier to peel?
97cavalier
01-03-2006, 01:37 AM
It is ammonia on philm tint. It can turn it purple and cause it to come off. The old tint with bubles is ALOT easyer to peel.
