Why not USE an FMU.
ZORT
06-09-2002, 09:46 PM
Why not use a fuel management unit by Cartech or Vortech that is exactly what i will be using on my home made project. I still found the afc a little too much for 5-8 psi.
kris
06-10-2002, 06:13 PM
How much do those run? I am not looking at spending alot on my forst go here. So if it cost more than the safc, I will pass on that.
ZORT
06-10-2002, 07:39 PM
From what I understand they run at about $80 to $150 still less than a AFC. That is partly the reason why i have decided on it. You can still add the AFC after when you have the change to fine tune it a step further. Still both of them don't run you into $1000 (ecu from Zydne etc) ;)
FBP Si 2000
06-11-2002, 12:10 AM
You would need an FMU since you would need some sort of fuel management. Unless you went with the AFC hack. In order to tune the car with an FMU setup, that's where the S-AFC or V-AFC comes in. Unless you went the standalone route.
kris
06-12-2002, 02:04 PM
So, are you saying I would need a AFC, and the FMU? Or just one or the other?
pvang31019
06-12-2002, 09:58 PM
It's up to you...go ahead and get the FMu is you want fuel pressures in the hundreds....
FBP Si 2000
06-13-2002, 04:38 AM
You would be fine with a FMU.
kris
06-13-2002, 09:52 AM
How about you explain please. Since this is a forum where we go to ask questions to learn. :)
pvang31019
06-13-2002, 05:53 PM
all the FMU does is increase fuel pressure....accompanied with an inline fuel pump....
you do not want to put this much strain on your stock injectors for a long time.
If anything, I would get some DSM 450 injectors and an AFC to control them
ZORT
06-14-2002, 06:46 AM
Now if we put everything together we get the following. Running boost will take a lot of fine tunning. To fine tune cost effectively you need the alter the air to fuel ratios accordingly at different rpm ranges and boost levels. Of Course you don't need to do all this at the begining stage. So we can start with an FMU on stock injectors.
Then an AFC to tune the a/f mixtures.
Then bigger injectors so you will now have a little more fuel to run more boost.
The reason i didn't put the bigger injectors before the AFC is because we don't want to run to rich on idle.
Also from what i am reading you can use the AFC and bigger injectors with an upgraded fuel pump (if you like) and have the same result I am not sure if you will need a FPR with that. The only thing is that the AFC is $300+ so I am thinking that we will start small and go with an FMU for about $100 to start and you fuel pressure will always be important in the long run because like anything else you will always want more.
So people tell me what you think about this write up.:cool:
kris
06-15-2002, 07:10 AM
Okay, I picked up the DSM injectors. So I'm good on those. Now I need to look into a bigger fuel pump. I was looking at the 255lph Walbro High Flow and High pressure intank fuel pump, which was what this guy uses (http://thenew.gamesbbs.com/~turbosi/). So I should be good with that, right?
But the fuel pump, and te AFC will be the most expensive parts. So for now, just starting off. I should be good to go with the FMU, and stock injectors.
Rgacke
06-16-2002, 02:10 PM
heres a good place to get pumps
http://www.autoperformanceengineering.com/
ZORT
06-17-2002, 06:37 AM
Guys I went up drags this sunday and i meet up with a guy running a nissan turbo from an RB25 on a B18B engine with 310cc injectors and an FMU on 9psi.
And guess what STILL RUNNING LEAN ... LEAN ... DAMMIT.. MY PLAN. So maybe the FMU cannot work?? help.. So maybe I will have to get the following to be safe:
Fuel pump $$$
FMU $$$
S-fac $$$
310cc or 450cc injectors $$$
So any of you guy running 5-6psi on an FMU and Stock 240cc injectors and stock fuel pump alone?
Fuel pump $$$
FMU $$$
S-fac $$$
kris
06-17-2002, 06:49 AM
Fuel pump $$$
FMU $$$
S-fac $$$
Not sure if you have these sites:
http://www.homemadeturbo.com/
http://www.turbocrx.net/
Just thought I would put them up for info...
Fuel pump $$$
FMU $$$
S-fac $$$
ZORT
06-25-2002, 04:30 PM
kbslacker and any one else notice that when you adapt the turbo to the hf or std manifold that the compressor housing is on the opposite side to the greddy kits. So for a 92-95 or up civic there would be no space if you wanted to run your air filter to pull in cooler air. Assuming of course you have a/c and power steering. Does anyone know why it could not go the other way is it because it wouldn't line up with the exhaust port from the header with out the turbine touching the engine?
Tominos
08-01-2002, 11:37 AM
it is because if you face it the other way, the turbine(exhaust side would be too big) and it won't clear the block. i am currently in final stages of my project and have experienced the problem. still, my wastegate on my turbo will not clear the block, i need to make adapter plate that positions turbo out about 2 inches from the block so it would clear my power steering and motor mount bracket. instead of the hole in the adapter plate, it has to be a big angle cut hole, don't know if that will flow too good. oh well.
pvang31019
08-01-2002, 07:16 PM
what we did was grind down the motor mount a little....
I can get you a manifold that is angled out to clear the block, but cannot use with AC
black 00 civic dx
08-22-2002, 05:27 PM
hey guyys, im looking to go the turbo route on my 00 civic single cam non vtec, and been putting together a setup with a guy from turbomanifolds.com and he's recommending a td-05 turbo ($250) for me, for full driveability and streetable, anyone else have opinions on what kind of turbo i should run? the td-05 gets full boost at 2500-3000 rpm, anyone know of anything around there , i only plan on running 5-7 psi.
ryan
ryan
