Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-01-2006, 09:14 PM   #1
mech1984
mech1984 Normal reputation
white smoke
i have a 91 camry i have heavy white smoke at idle and at accelration I have replaced the head gasket and got the head resurface and pressure check for cracks i put the head on and started it up and it's still doing the same thing i can see the compression from the radiator is it any thing after then a warp0 block deck that's causing this problem any help will be helpful
mech1984 is offline   Reply With Quote
Old 01-02-2006, 12:25 PM   #2
Toysrme
AF - Advisor
Toysrme's Avatar
Toysrme Normal reputation
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool
It takes a little while to evaporate the coolant & oil out of the exhaust pipes. It may just be that.
Or ya, the block could have been warped also, but that is fairly rare. Iron blocks are so much stronger than aluminum heads. The Aluminum is gaurenteed to warp first & normally the iron blocks don't do anything.
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
Toysrme is offline   Reply With Quote
Old 01-03-2006, 12:41 PM   #3
furias15
furias15 Normal reputation
Re: white smoke
If you mean you can see bubbles in the radiator this is not good. It means something is cracked. What does a compression test show?
Steve
furias15 is offline   Reply With Quote
Bookmarks
Google
Web AF
