Heater blower only works on high speed
mtignor
01-01-2006, 08:39 PM
The heater/AC blower motor on my 2002 Status will only work in the 2 highest speeds (3 & 4). The low speeds (1 & 2) act just like the off (zero) position. I'm thinking this is a problem with the dash control unit. Has anyone had any experience with this problem? Could it be something other than the dash control unit? Thanks
stratusse2001
01-02-2006, 09:00 AM
In my 2001 the low speed do very little. I brought it in and they told me it was normal. So I think they should do only very limited blowing on these speeds.
vanco27
01-02-2006, 09:08 AM
It is your blower relay switch. it is located behind your glove box. The part is about 25 bucks and easy to install. Hope this helps you .
mtignor
01-16-2006, 01:38 PM
The problem was not solved by replacing the dash contol unit. I will try to replace the blower relay switch as you suggested and see if that solves the problem.
HeadlessHorseman
01-23-2006, 04:09 PM
More likely it's the Resistor Block.
This is for Minivans, but concepts apply...
http://www.automotiveforums.com/vbulletin/showthread.php?t=340871
alaskandl
01-30-2006, 03:06 AM
Hey guys,
I've got this problem as well, but it went from 2 settings to one to none, and with it being below zero up here it isn't fun. I've got the haynes manual and I can't find anything about the blower relay switch. Do you mean the
blower resistor? If not how do I get to the relay? Thanks
DODGEorNOTHING
04-11-2006, 09:51 PM
ive got me a 99 stratus 2.4l 4dr sedan and ive got this problem also and i am almost completely car illiterate. whats a resisor block.. all i know is that it sucks that i only have high!!! its noisy i'm cheap, i know nothing and i'm lazy whats the way to fix it in idiot terms and how much?
eXcelon
05-05-2006, 08:47 PM
for the older stratus 95-00 heres more info on replacing the blower resistor http://www.stratusphere.net/forums/FIX_HVAC_fan_works_on_high_only-t20297.html
brvanginhoven
05-08-2006, 08:51 AM
Replace your blower motor resistor. I've had this problem twice except with me the fan only worked on #4. Shouldn't cost you more than $25 and an hour to replace. It's located by the blower motor under you glove box compartment against the firewall.
