Originally Posted by stc78
hi i have here today a 94 astro with a cold start problem,now ive checked the basics,
fuel pres 50-60 psi,
spark yes,
changed fuel filter,
no drop in presure when sitting (which would rule out spider right?)
starts and runs excellent with a little juice at startup (either)
after that starts once warm every time
runs beautifull very smoth and quiet
now for the interesting the van 4.3 w cpi,has 234,000 miles when i bought it had a hellatious rod knock but it still ran well, but it had the cold start problem, now i replaced the motor with a 100,000 mile canidate i had in the garage, finshed it up and it started right up ran perfect, note 60-70 degrees inside, put it outside next morning no start 20-30 degrees, a little juice and away we go
now ive heard people say something about a pulsator? but what does that acually do? would it cause my problem, fuel pump? and you know im looking for any excuse not to drop the tank, its been sitting for some time and its not pretty but im out of options.
ive been throgh every sensor and wire and im confident its not the electrical system, well ive been wrong before but pretty sure, it also has a new fuel pump relay
id appreciate any help or input you guys could shoot my way thanks a lot, man in disgust.
Pulsator is in the fuel tank on the fuel pump assembley if it has one .
It is a damper for fuel pressure bit if bad can leak fuel pressure.
Your fuel pressure readings are on the low side specs are 55/61.
You need 60 lbs on a cold start to squirt injectors.
Also it you have a fast leak down after key off you have a leak someplace.
Hard to start cold.
Check cold start fuel pressure.
Check engine running fuel pressure.
Check engine running on the road fuel pressure.
Then shut it off and watch for fast leak down.
Pinch off at rubber part or block off return line and check full pressure.
Later V6 and V8 gm engines should have 60-66 fuel pressure.
Cold start should be 64-65 lbs of pressure.
Yours should be 59-60 cold start.
If you do not have full fuel pressure on a cold start the injectors will not squirt fuel.
Do not leave home without it.
Engine running should be 55/61 lbs pressure depending on engine load.
Full pressure with return pinched off should be 75-85 or more.
And if it has a fast leak down after shut off you have a leak.
Post back your fuel pressure readings.
MT
