TransmissionDeeDeeG20 06-09-2002, 04:40 PM I have a 1995 G20 Infiniti. When I come to a complete stop and proceed to go, the car thrusts. I called my mechanic and he said it sounded like the transmission. It is now 1 month that I don't have my car and my mechanic can't seem to locate the problem. I'm at wits end, because, I don't think I can really afford to bring to the dealership. What do I do. I am a female and I really don't know anything about cars. My brother recommended this site to me and I did find something that seems just like my problem and the solution was the EGR Valve. Any other ideas. Thanks for any help you can give me. eeyore 06-11-2002, 01:16 PM Can you expand/explain "the car thrusts" a little more? How many miles has the car done?? DeeDeeG20 06-11-2002, 10:30 PM Thanks for the reply, I have 67,000 miles on the car and whenever I make a full stop, the cars gives a hard kick when I go into first gear. I am okay if I coast, but once I make that full stop, it does it again. I have an automatic. Hope you can advise. Thank you again boingo82 06-11-2002, 10:30 PM Deedeeg20 just reported this thread with this info: My car has 67000 miles, when ever I make a full stop and proceed to go, the only way I can explain it is, it gives a hard kick going into first gear. It's an automatic. Once I am driving its fine, but as soon as I make another full stop, it does it again. Its even fine when I coast. Only after a full stop. Thanks for the reply, hope you can help me. Hope someone can help her out. Emily eeyore 06-12-2002, 04:25 AM First thing I'd do is check the transmission fluid. The auto box probably has a hydraulic clutch (can anyone confirm this?), in which case it may well be low fluid. Second thing I'd do is check your "kickback switch". Again, I don't know the system on your car, but most auto's have a switch on the accelerator so when you floor it, it tells the gearbox to change down. Make sure this is still working. (simple test is when driving - put your foot down and it should change down a gear, pull your foot up and it should change up. Drive at a constant rev and it shouldn't change at all). If these two don't come up with anything, then I'm afraid it's an autobox problem. Sounds very much like a hydraulic problem, so you may get away with a simple replacement seal, rather than a new gearbox. Find a good local gearbox specialist - since most garages send gearboxes away to specialists (but add their margin in on top). T4 Primera 06-20-2002, 05:08 AM The cause of a number of tranny problems in these cars is that the fluid filter in the oil pan gets blocked up with clutch material. Hard shifting from a stop as you describe can certainly be caused by this. Others have experienced similar problems going from neutral to reverse and neutral to first gear. DeeDeeG20, I suggest you print out this webpage: http://www.se-r.net/transaxle_clutch/auto_lsd_info.html and give it to your mechanic. Tell him to read the 2nd and 3rd paragraphs he'll know what to do. Best of luck :) Automotive Network, Inc., Copyright ©2012
