Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 12-30-2005, 09:52 PM   #1
ProMorpher
ProMorpher Normal reputation
Question 95 Astro fuel problem?
I have a 95 Astro and it has recently started to run rough. I don't know the best terminology to use to describe it, but when I accelerate there are hiccups. That is, the van will begin to accelerate, stop for a second, and then resume accelerating. The problem stops instantly if I stop accelerating.
On top of the surging or hiccuping during acceleration, the van has also struggled to start a few times in the past couple of weeks. Each time it eventually turned over, but only after several attempts at turning the key and mashing the accelerator the floor.
Does anyone have any idea where I should start troubleshooting? Does this sound like a possible problem with the fuel system? Thanks for any help.
ProMorpher is offline   Reply With Quote
Old 12-30-2005, 10:01 PM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: 95 Astro fuel problem?
How many mile since last tune up?
Any check engine lights?
Start with a good tune up.
Fuel pressure and fuel filter also.
MT
MT
MT-2500 is offline   Reply With Quote
Old 12-31-2005, 08:16 AM   #3
CD Smalley
CD Smalley Normal reputation
Start with a proper test of the fuel pressure.
Sounds like you have a weak pump and or a leaking spider unit.
CD Smalley
1991 W41 #142
1995 Astro
1989 Caprice 9C1
1997 C1500
1977-90 GM B-Body email list Owner @ yahoogroups.com
In the recovery room: b-body.org...
CD Smalley is offline   Reply With Quote
Old 01-09-2006, 10:23 PM   #4
e7ats
e7ats's Avatar
e7ats Normal reputation
Send a message via AIM to e7ats Send a message via MSN to e7ats Send a message via Yahoo to e7ats
I'm with CD on checking your fuel pressure.
There is a port on the back side of the engine to check the fuel pressure. Start and run, the pressure should come up over 50 PSI. Shut the engine off and the pressure should hold over 40 PSI for a long while. If it does not come up to 50 PSI or hold at 40 then it sounds like the Fuel pressure regulator on the spider injector unit is leaking. This will over fuel the enigine giving the symptoms you have.
03 Astro AWD Personal
04 Safari AWD Cargo Comapany
92 Taurus with 270,000 miles on it.
e7ats is offline   Reply With Quote
Old 01-10-2006, 08:41 AM   #5
MT-2500
AF - Advisor
MT-2500's Avatar
Re: Re: 95 Astro fuel problem?
On a 4,3 W engine fuel pressure specs are 55/61
Do not leave home without it.
Also you can have fuel pressure leak off at several places beside the fuel pressure reg.
MT
MT
Old 01-18-2006, 01:11 PM   #6
drew300
drew300 Normal reputation
Just a thought.
How about a sticking EGR valve?
drew300 is offline   Reply With Quote
Bookmarks
Google
Web AF
