Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 12-30-2005, 11:56 AM   #1
trippah60
trippah60 Normal reputation
service engine light on
I have a 95 s10 with a vortek engine. I tried the jumper method to get the code and here is what came out not sure how many codes this is. Each set flashed 3 times, (1 flash then 2) (1 flash then 5) (3 flashes then 2) (4 flashes then 3) any help with this would be greatly appreciated.
trippah60 is offline   Reply With Quote
Old 12-30-2005, 01:06 PM   #2
RahX
RahX Normal reputation
Re: service engine light on
15-low temp indicated
32-egr
43-knock sensor
code 12 will always be displayed, its like a communication test code or soemthing. its irrelevant. have you done anything to the truck recently?
RahX is offline   Reply With Quote
Old 12-30-2005, 04:06 PM   #3
trippah60
Re: Re: service engine light on
32-egr
43-knock sensor
Ok a lil update, vehicle also had a hard starting problem after running and being shut off for a while, cranks like 20 secs before it starts and blows a puff of smoke out the tail pipe. Today i replaced both temp sensors,temp gauge wasnt working either, guage works now but still have same starting problem. I reset the computer and now im just getting the 43-knock sensor code
Old 12-30-2005, 08:10 PM   #4
rlith
rlith's Avatar
rlith Normal reputation
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Re: Re: service engine light on
The hard start may be do to a leaking CPI and/or nut kit.,..Pull your upper plenum and check for washing. Also run a pressure test on your fuel system. Clamp off the return line. If it doesn't hold pressure your fuel pump could be dying out. Your pressure should be at 56-60 to start.
For the knock sensor you need to replace it.
You have 2, 1 on the driver's side of the block. Between and below the 3 and 5 plugs. And you will have another 1 on the back of the passenger side head against the firewall.
rlith is offline   Reply With Quote
Bookmarks
Google
Web AF
