oil problems HELP
Google
Web AF
AnarchyB52
12-29-2005, 03:30 PM
i have a decent oil leak coming from the passenger side of the engine
it seems to be originating somewere above the oil filter
it drips alot worse when the vehicle is running
i dont have oil in the antifreeze and there is no white smoke from the exaust
so far people tell me i could be the oil main seal(which isnt on the passenger side)
the head gasket(which i just replaced)
the valve cover gasket(which i just replaced)
or the camshaft seal
PLEASE HELP ME!!!!
knotters2006
12-30-2005, 01:18 AM
there is an oil pressure sending unit there , it could be leaking from there also, they go bad somtimes
wafrederick
12-30-2005, 02:44 PM
Probally the camshaft seal,it will pop out by it's own and I have seen that.It might be around the camshaft sensor,remove the camshaft position sensor and put a light coat of RTV silicone around the o ring area
tch1717
01-07-2006, 07:47 PM
it wouldn't be the cam sensor seal or the oil sending unit (both on drivers side of engine, pass side above oil filter, could be crank sensor o-ring, or cam seal
Google
Web AF
