Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > C/K
Old 12-28-2005, 09:13 PM   #1
juniorcarp
juniorcarp Normal reputation
Angry 95 ck silverado rough idle when cold
I have a 4.3l ck pickup and when i start the truck sometimes its stalls or runs a little rough when give it some gas in neutrel it runs fine......when i start driving when its still cold it runs fine cause the choke is picking up but when i cometo a stop at light or a stop sign and re accelerate it totally bogs down like it starving or flooding and it sometimes stalls but will restart it will carry through most times if i floor it and goes all the way up to 3000rpm and goes back to normal this continues till its warmed up and i never have a probelm the rest of the time its at proper idling temperture this has become very frustrating i did a tune up on it changed the plugs wires and cap and still the same issue HELP !!!!!
juniorcarp is offline   Reply With Quote
Old 12-29-2005, 02:05 PM   #2
horse482
AF -Advisor
horse482's Avatar
horse482 Normal reputation
Re: 95 ck silverado rough idle when cold
It could be the coolant tempature sensor, for the ecm. I had the same problem with a 5.7 vortec, I changed the cts and the problem was gone. Hope this helps.
horse482 is offline   Reply With Quote
Old 12-29-2005, 11:21 PM   #3
Krayzie_Bone
Krayzie_Bone Normal reputation
I have the same problem with a 1988
Krayzie_Bone is offline   Reply With Quote
Old 12-30-2005, 02:00 AM   #4
Crasen
Crasen Normal reputation
Is the check engine light on? If it is then get the codes read, you can go to Auto Zone, Advance Auto, or some other auto parts stores and get trouble codes read. Or since you have a 95 you can try getting the codes yourself. As far as I know a 95 does not have OBDII. OBDII did not become a requirement untill 96 but some vehicles had it in 95 models. Look for a black connector under the drivers side dash. If you have one with 12 pins in two rows it is not OBDII and you can pull codes yourself. All you have to do is get a piece of wire strip the insulation off both ends and jumper pins A and B( they are on the top row, A is the far right pin B is the second one from the right) you could also use a paper clip. Turn the key to the run position. The check engine light will start to flash. the first code will be 12 one flash followed by a short pause the two flashes. It will flash 12 3 times, then if there are any trouble codes stored they will flash, each code will flash 3 times. After all trouble codes flash 12 will flash three more times. Even if your check engine light is not on I would check for trouble codes anyway. After you get trouble codes I would write them down and reset the computer. just remove negative battery cable for 5 minutes. Then after driving see if they come back. Hopefully that will narrow the problem down. If that doesn't help I would look for a vacuum leak and see if you have carbon build up at the IAC valve
Crasen is offline   Reply With Quote
Bookmarks
Google
Web AF
