Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 12-28-2005, 03:39 PM   #1
Smiff 24
Smiff 24 Normal reputation
94 Camry EGR replacement
Hey all,
I have a 94 4 cyl.
Hows the best way to replace it ? (egr valve)
the egr valve is close behind the valve cover,
does the tube going down to the block come off too ?
it looks like the whole thing has to come off to unscrew the egr
from the tube .
any help is appreciated !!
RC car Nut !
Smiff 24 is offline   Reply With Quote
Old 12-28-2005, 04:28 PM   #2
Daniel M. Dreifus
AF -Advisor
Daniel M. Dreifus Normal reputation
Re: 94 Camry EGR replacement
May not be worth the extra effort to you, but I noticed when I changed the distributor O ring and had the distributor out, that pipe to the EGR valve was accessible at both ends.
Daniel M. Dreifus is offline   Reply With Quote
Old 12-30-2005, 06:23 PM   #3
majones
majones Normal reputation
I had an easier time getting a wrench on the pipe end attached to the block and took the egr and pipe out as a unit; its easier to get at the other end once its off the car.
You may be able to clean the egr rather than replace; clean out carbon deposits with carb cleaner spray and pipe cleaner or wire. Check to see that the plunger in the egr operates freely. You'll probably need a new gasket for the egr. Good luck
majones is offline   Reply With Quote
Old 12-30-2005, 10:19 PM   #4
Smiff 24
Yea, thats a good idea, probally need to clean the pipe as well.
cleaning is free, new egr $180 I think!
Got more time than money !!!!!!
Tks for the info.
RC car Nut !
Bookmarks
Google
Web AF
