Re: changing tire size
If the new tire has a larger diameter or is wider than the original tires you could have clearance problems and rubbing. (tires on fenders) If it is smaller you could have scrapping problems. (under carriage on ground) Either way your speedometer/odometer will be off, but it will not effect your tachometer. Choose new tires with close to the same overall diameter as the originals and you will minimize problems and shouldn't have to change anything else.
Mark's Garage est. 1983
