1997 chev tahoe , hard start
Google
Web AF
mtwig
12-26-2005, 08:09 PM
I have a 1997 chev. Tahoe 5.7. It has to be cranked 3 to 4 times before it starts most of the time other times, it will start just fine. I did replace the plugs, wires, cap, and rotor befor this started happening. Also the weather has changed from mild to cold, but not real cold since the tune up. I have heard of a possiable pressure leak in the fule system???
Any one have any suggestions?
95tahoe4x4
12-27-2005, 01:35 AM
PCV valve? Fuel Filter? Air Filter? were these replaced as well? The Fuel Filter should be done every year.
How long do you crank? 3-5 seconds?
I turn the key on for 2-3 seconds, then crank, it fires much quicker. This seems to give the fuel pressure time to build.
Kt
GMMerlin
12-27-2005, 05:46 AM
Could be a couple things causing this.
Fuel pump check valve allowing fuel pressure to bleed back
Leaking fuel pressure regulator
Lean injector poppets
Google
Web AF
