FAQ and How to's Inside! READ ME!!!!!!!!!
Shortbus
12-22-2005, 11:15 AM
Frequently asked questions and How-to's for GM S/T bodys Special thanks to blazee, OverBoardProject, 93LT, laxman21, Brian R., and the thread creators as well as anyone else I missed.
Click links below for how to sections
Please report any dead links to shortbus@af via PM or any other questions about this faq, John
Please Read Blazee's post first before posting or scroll down to the second post in this FAQ Thank you!!
How to Post for maxium responses as well as User Guidelines (http://www.automotiveforums.com/vbulletin/showpost.php?p=3666343&postcount=2)
Want to Sell or Buy a Car or spare parts?, Post it Here (http://www.automotiveforums.com/vbulletin/forumdisplay.php?f=1269)
Body/Paint Exterior
Rust repair around windsheild (http://www.automotiveforums.com/vbulletin/showthread.php?t=495267)
Replacing door hinge pins and bushings. (http://www.automotiveforums.com/vbulletin/showthread.php?t=363334)
Replacing door hinge pins and bushings Illustraded (http://www.automotiveforums.com/vbulletin/showthread.php?t=476619)
Restore your weathered plastic how-to (http://www.automotiveforums.com/vbulletin/showthread.php?t=391672)
Engine Performance/Diagnostics
4.3 CPI Injector replacement (http://www.automotiveforums.com/vbulletin/showthread.php?t=473110&highlight=4.3+CPI)
***92 - 95 CPI Engine Info.*** (http://www.automotiveforums.com/vbulletin/showthread.php?t=462726)
Fuel economy and General Maintenence reccomendations (http://www.automotiveforums.com/vbulletin/showthread.php?t=453370)
List of OBD II Codes (http://www.automotiveforums.com/vbulletin/showthread.php?t=425701)
Basic Cooling System Advice (http://www.automotiveforums.com/vbulletin/showthread.php?t=456944)
Got air in your heater core? Need help getting rid of it? (http://www.automotiveforums.com/vbulletin/showthread.php?t=469926)
Water Cylinder Decarbonizing... Should I? (http://www.automotiveforums.com/vbulletin/showthread.php?t=283211)
A Little Info About Fuel Trims (http://www.automotiveforums.com/vbulletin/showthread.php?t=429831)
96+ Hard Start, No Start, Rough Idle Info (http://www.automotiveforums.com/vbulletin/showthread.php?t=450484)
96+ Water Pump Replacement (http://www.automotiveforums.com/vbulletin/showthread.php?t=498467)
Brakes, Suspension, and Drivetrain
1995-2003 S10 & Blazer Front End Clunk Pop Fix!!! Read!! (http://www.automotiveforums.com/vbulletin/showthread.php?t=302656)
Drum to Disc brake rear end swap how-to! (http://www.automotiveforums.com/vbulletin/showthread.php?t=372515)
Transmission Problems: Common Issues and Solutions (http://www.automotiveforums.com/vbulletin/showthread.php?t=461182)
Read for Help **ABS Activation At Low Speeds** (http://www.automotiveforums.com/vbulletin/showthread.php?t=425516)
Ignition Electrical and Wiring System
First Gen Instrument Cluster Conversion (http://www.automotiveforums.com/vbulletin/showthread.php?t=489642)
Ignition Switch replacement procedure (http://www.automotiveforums.com/vbulletin/showthread.php?t=287636)
Heated seat how-to! (http://www.automotiveforums.com/vbulletin/showthread.php?t=366533)
Factory fog lamp switch with non factory fog lamps. (http://www.automotiveforums.com/vbulletin/showthread.php?t=356665)
Everything Interior/ Audio
blazee
12-22-2005, 12:49 PM
Hello, and welcome to the Blazer forum. We are always happy to get new members. Feel free to assist others with their problems or ask for help with your own, but be aware that there are a few rules that everyone must follow.
Please read the forum guidelines (http://www.automotiveforums.com/vbulletin/guidelines.html). All members are expected to follow these simple rules.
If you have an issue that you need assistance with, there is very good chance that you will find help here. Our members are very knowledgeable, and would be happy assist you. Due to the high volume of traffic that this forum sees, there is a procedure that must be followed to insure that everyone receives quality help in the shortest amount of time.
1. Read the FAQs and How-tos
2. If the answer is not found, use the search feature. There is a great wealth of knowledge that can be achieved with that little search button.
3. If you still need further assistance start your own thread. DO NOT post your question in someone else’s thread, this only creates confusion.
4. Make sure that your thread includes:
1. A clear title. Make sure it gives a hint as to what information you are seeking. Threads with titles like “HELP!” or “Need help with……” are often ignored, because they are obnoxious.
2. Vehicle information. List the Year, Model, Engine (eighth letter of the VIN #), and Miles or KM.
3. A detailed description of the problem. The more information you provide will allow us to better assist you.
4. When your Check Engine or Service Engine Soon light is on, your car’s computer has detected something that needs attention. When this occurs there is a trouble code stored. When possible please include this code. See the topic “List of OBD II Codes (http://www.automotiveforums.com/vbulletin/showthread.php?t=425701)” for more information.
5. List any recent work that has been done, and any attempts made to fix the current problem.
5. Please only post your thread once. Multiple threads are only an annoyance, and do nothing to improve response time. (unless you're seeking a negative response :evillol: )
6. After posting your thread please be patient. The members of this forum are volunteers and have lives outside of AF. As soon as someone that has information about your problem sees your question, they will reply.
