Re: For those of you who have laser/radar detectors. Mine any good?
The Whistler should do the job nicely as long as it covers the ka and laser bands, which I believe all the Whistlers do.
The best placement for a radar detector is below your rear view mirror. The reason is because it can see everything you can. If you put it on the dash it may not see 360 degrees there's allot blocking it, but it should still get a good view of forward.
Well placed the detector can see police (while their beacon is on), as well as ambulances warning areas with construction or safety zones, etc. at an impressive distance. Most of the times I know they're on the way before they are even visible, but when placed low to the dash it doesn't pick them up.
Radar takes a great many variables. If you've seen the Myth Busters episode where they continually tried to trick the light they failed, so don't think that because you own a black car or have a non-reflective surface that you have any chance against radar. Trust me, just give up trying to beat it.
Remember that no matter how good your detector is it takes one beep on the laser band and it's all over but the ticket. So in reality, no detector is flawless, so just drive safely and you really don't have to worry at all.
