88 Jeep Juice to positive wire(Red)/Need your help plzMike_jeep_88 12-25-2005, 05:14 PM Guys I need help, my Jeep did not turn over after I parked it. There were no dash lights, no cranking. It went dead but battery was fine, headlamps worked the interrior light worked the starter relay was sending juice, the starter I cranked by connecting Positive and negative at ends of starter. I learned all this by reading this wonderful message board. Well finally I got it started. The problem was no jiuce to Red wire for ignition. Now my question is how can i run power to this particular wire or should I need to check why it does not has power. The NSS was checked by disconnecting it and the jeep did not cranked at all even with power to Red wire. Your suggestions will be greatly appreciated. BTW it is a 88 Jeep 4.0 auto trans. Happy Holidays!! EZFrank 12-25-2005, 11:48 PM Probably a fusible link or a fuse good luck hope you get her going. mojomachine13 12-26-2005, 11:20 AM fuze, relay, or even alternator? Automotive Network, Inc., Copyright ©2012
