about to buy an fcATMDC 12-25-2005, 01:32 PM im about to buy a turbo II, and i just wanted to know, what all should i replace on the car when i get it (a good website link is also helpful for this) i have only been able to find specs., and how much should all the parts cost? i really want to make this a reliable car. also whats the best repair manual for the turbo II? thanks very much for the help FDTT 12-25-2005, 04:18 PM Ummm replace wear and tare parts. Vacume lines hoses flush rad replace belts replace plugs plug wires every bushing in the car change oil and filter change diff fluid change and bleed clutch fluid change and clean brake fluid replace cold start fluid new thermo wax pellet new TPS tires aftermarket water temp guage shifter bushings air filter bulbs wiper blades rad caps ECT ECT The list is endless bud. The car is old, replace EVERYTHING you can afford to do. Then and only then modifie the car. drftk1d 12-25-2005, 04:32 PM best repair manual is the FSM check the FAQ Soyo 12-26-2005, 09:40 PM buy my car :) authoriti 12-27-2005, 12:28 AM Full factory manual at www.ilovemyrx7.com Sites a little slow, but it's pdf and everything you need. Ok just used the link and the site appears to be down or has closed, but it used to have all the factory manuals. drftk1d 12-27-2005, 10:07 AM Full factory manual at www.ilovemyrx7.com Sites a little slow, but it's pdf and everything you need. Ok just used the link and the site appears to be down or has closed, but it used to have all the factory manuals. FSMs are right here: http://208.62.166.66:82/guest/shop_manuals/ check the faq Automotive Network, Inc., Copyright ©2012
