97 Blazer Thermostat Help and No Heat (Pics)
Douflag
12-25-2005, 01:05 PM
Happy Holidays! I've been reading this forum a lot lately, especially on the problem about the thermostat. Here goes my situation:
*My 97 Blazer thermostat doesn't go past the 100 mark. I'm not sure if it's a gauge problem or the thermostat itself.
*There's lukewarm air blowing out of the vents when I turn on the heat.
*I did a coolant flush at an auto repair shop, which didn't help w/heating problems.
*I'm now trying to replace the thermostat myself, but I'm having a lot of trouble trying to get to it. First off, I'm not sure if I'm looking at the right thing. I followed the upper radiator hose to the engine block. I have a pic below:
http://tinypic.com/j65w15.jpg
*If that is the thing, how do I remove the bolt behind the radiator hose? I also put a pic of it below:
http://tinypic.com/j65yk6.jpg
Removing that bolt seems a little complicated, and looks like I'll have to remove some more parts that are obstructing it. From what I've been reading, it sounded pretty easy to replace the therm, so I don't know if I have the right thing. Any suggestions/ideas?
Blazer SS
12-25-2005, 10:15 PM
What I used was a 6in extension with a whobble or universal socket. If that doesn't work for you, the old standby, remove the egr valve and use a open end wrench. You also get to see the condition of your egr spring.
Douflag
12-26-2005, 01:57 PM
Alright, I was finally able to get the thermostat out yesterday, when I unbolted where the arrows are pointing at:
http://tinypic.com/j7ayqr.jpg
There was some leakage of the coolant, b/c I wasn't able to find the petcock on the radiator so that I could drain out some coolant beforehand. When I checked the level of the reservoir engine coolant tank, it wasn't at FULL, but it wasn't below the ADD level either. Should I put some more coolant in there? Is it okay to just add coolant instead of doing the whole flush procedure? Thanks!
Southern Comfort
12-26-2005, 02:29 PM
Yes, just add more coolant or water. and keep checking it periodically, because those engine are bad about leaky intake gaskets.
laxman21
12-26-2005, 02:57 PM
http://img.photobucket.com/albums/v448/therealsundance/DSCF0166.jpg
