Update...bad news :(
-al-
12-24-2005, 12:54 AM
99 ram 2500. 79k miles. Been running great, but last night it died while driving. Tried to restart and runs very rough and smelling fuel. Had it towed to a garage, and they found 7 cyl running 60lbs compression and 1 at zero. Took valve cover off and saw a broken valve spring. Must have jumped time? Mechanic said the dodges use a plastic gear for the timing chain and they go often. Anyone else had a similar problem?
-al-
12-24-2005, 01:01 AM
Wanted to add that a valve is bent (the one that has the broken spring)
imtheoneandonlyD
12-24-2005, 01:34 AM
yikes, sorry to hear the bad news. Do you have an estimate on how much to fix it?
-al-
12-24-2005, 02:37 PM
No $ estimate yet, but they said 8 hrs to do timing gears & chain. Plus the 8 hrs allready spent plus the tow. Probably looking at $1200 or so. I wonder if this would be covered under a Dodge warrenty?
fredjacksonsan
12-27-2005, 08:34 AM
Pretty close on the warranty.....if you have the 7/70 then Chrysler may help out a bit, but don't count on it. Definitely worth looking into, especially if you've had it regularly serviced @ the dealer.
-al-
12-27-2005, 06:44 PM
No, have not had it regularly serviced at the dealer - maybe once a year for a check out/oil change. I am going to try anyway :) ...cant hurt to try. I am just so shocked to have a timing chain/gear/valve/spring fail at 79k when I really baby the motor on this truck. Never rev it out or anything like that.
imtheoneandonlyD
12-27-2005, 09:04 PM
Please tell me you get an oil change more than once a year.
BleedDodge
12-27-2005, 10:38 PM
That's what I thought when I saw that too...
fredjacksonsan
12-28-2005, 06:52 AM
Me, too. I'll be interested to see how this comes out.
neon_rt
12-28-2005, 01:58 PM
The once a year oil change would explain the engine having problems.
I change my oil every 6,000 miles (Mobile 1), at 3,000 I change the filter and top it off, at 6,000 it gets a complete oil/filter change.
-al-
12-28-2005, 07:47 PM
I change the oil every 3500 miles like clockwork, but I bought the truck with 69k on it so no idea what the previous owner did.
fredjacksonsan
12-28-2005, 09:33 PM
Cool; any word from Chrysler on the engine?
-al-
12-29-2005, 08:40 PM
I dont know where to start...should I call the dealer or dodge directly to get warentee info?
fredjacksonsan
12-29-2005, 08:52 PM
Start at the dealer, escalate to Chrysler. They've got resolution processes in place for it.
First step will be to see if you had the 7/70 or the 7/100 powertrain warranty; I know it changes back and forth once and awhile. If you have the 7/100 you are golden. 7/70, will have to work it. Be prepared to show records for service, and oil changes if you have them.
Good luck...
neon_rt
12-30-2005, 12:00 PM
The factory warranty doesn't apply to a second owner unless a warranty transfer form and $150 fee is paid by the new owner.
At least that was the case a few years ago when I bought a used Dodge.
fredjacksonsan
12-30-2005, 12:13 PM
Good point.....hopefully it was purchased new though....:p
