Losing brakes
dolfins1a
12-23-2005, 05:55 PM
1994 S-10 with ABS while I'm braking if I happen to hit a pothole or if under hard braking and the ABS kicks in, I lose almost all of my pedal. It nearly hits the floor. The only way to get it back is to bleed the system and the problem is corrected until the next time. I've checked for leaks and there is no loss of fluid to be found. Anyone have any ideas what would cause this? Any help would be greatly appreciated.
sector95
12-23-2005, 09:58 PM
I believe there's a TSB on this. I had a '91 w/ABS and it would do the same thing. There's supposedly a fix for the ABS computer.
mike
dolfins1a
12-26-2005, 10:19 AM
mike I had the new software installed back in 2001 unless there was a more recent one. Thanks for the reply
RahX
12-26-2005, 04:02 PM
is it rear abs only or?
dmbrisket 51
12-26-2005, 04:50 PM
could be a leaking/bad accumulator in the dump valve, dont ask where it is, that is your baby to find, but the do go bad and would cause a 'needing bled' problem
RahX
12-26-2005, 07:51 PM
well the old RWAL systems, the dump valve was big enough to hold a LOT of fluid. under normal abs braking it wasnt so bad but if you did a pedal pump or two while under abs braking it could fill up.
dmbrisket 51
12-27-2005, 12:36 AM
dump valves are a failure item
