Problem with fiesta even garages can't locate!
Google
Web AF
jayzzz
12-19-2005, 06:50 PM
Hi all, got a problem with a Ford Fiesta, and so far 3 knowledgeable people and 2 garages have not found a cure! Hopefully someone here might
have had a simalar problem and may be able to help? I'm not very car knowledgeable so please bare in mind when explaining anything :)
Description of the car:
Ford Fiesta 1.25 (1242cc) LX 16V Zetec-S injection - 1996 N reg
The problem is, when driving the car, at random intervals it 'judders' and loses power, sometimes nearly coming to a stand still. Even when
putting your foot right down when this happens, no fuel/power seems to be going through to the engine, and so, no acceleration.
This has happened in all gears, at all speeds, and at totally random times - Sometimes seconds after setting off, sometimes doesn't happen
for a few minutes, and sometimes doesn't happen at all. Also when it does happen, after the power is finally back, it maybe fine again for
ages.
After a while after the lack of power/speed thing happens, with your foot flat down, all of a sudden the power kicks in, and sometimes
excessively so it accelerates really fast. While the power stops, it builds up, and after a while it all comes out. Today it was even worse,
when putting it into 5th gear no power was going through whatsoever, so even had to drop back down into 4th just to keep at the right speed.
Before getting the car it had been on a driveway for quite a while but don't know how long. The car is also high on CO2 emmisions, but
recently passed an MOT 3 weeks ago.
If it helps find a cure, another weird thing about the car, when changing the spark plugs, the old ones were covered in oil, meaning oils
coming up from inside the engine past the pistons which they shouldn't so maybe that's something to do with it?
Everyone has suggested many possible fixes, such as new spark plugs, fuel filter, oil filter, of which I have done all, to no result. I have
tried using Redex in the fuel to get rid of any muck deposits due to an ancient corroding rusted old fuel filter, which hasn't really helped.
Newer suggestions for cures were:
Lamba Sensor renewal - could also cure the emmisions problem
Distrubutor cap?
Anyone that has any suggestions please reply, we're really on our last legs trying to find a cure as no one else seems to know the problem!
Jason.
sweenster
12-20-2005, 04:02 PM
my first thought would be that the ECU is faulty. Probably not totally f3cked up but there might be a loose wire in the connection (possibly try checking the power supply wire in the first instance).
Maybe even a hardware fault with the ECU itself? The unit may reset itself after it cuts out which would explain why it works OK for ages afterwards before it happens again.
fordfestauk
03-12-2006, 10:14 AM
Hi there mate i am having the same prob with my ford festa L reg 1994 the power dies i have been told so many things that it could be the one thing i know is when i drive through water it sets it off there for i am 99% sure that its my lamber sensor but still need help when you take your foot off the gas then put it back on gently does it gain power again?
jayzzz
03-14-2006, 06:40 PM
Hey, Sorry it's taken a while to reply, been busy at work. When taking the foot off the gas and putting it back on slowly it didn't really do any different.
The way the power kicked in eventually was by putting ur foot flat down on the gas pedal and randomly it'd kick in.
We since took it to a Food garage to run it through their diagnostics machine.. which cost £60. The test came back saying the "Hego Sensor" needed replacing. Since replacing the hego sensor, the problem seems to have been fixed. I'm not suggesting yours is the Hego Sensor, but it could be a possible cause!
Best bet if I were you is to take it to a Ford Garage for electronic diagnostics.. it costs £60 but it'd most probably find whats wrong. Only thing is with this test to note is that when the test finds a problem which could be a cause for your symptoms, the test stops. You may replace that part but then have to do the test again to find anything else which needs replacing (This is just a way in which ford attempt to make more money out of you) fortunuately for me the Hego Sensor was the cause for the problem.
So i'm basically suggesting you run it through Ford's diagnostics, replace the part (Hego sensor replacement including labour cost £140 via ford, but would be cheaper elsewhere.. we got fed up so went with ford), and hope for the best! (...or get a new car lol)
Let me know how it goes mate,
Jay.
fordfestauk
03-15-2006, 03:48 AM
Hi Jay thanks for your post i have not yet fixed the prob but the mad thing is the car is working really better not sure why your right i do need to go to ford and put the car on a test then we will find out the prob i will keep you up dated thanks bud
fordfestauk
03-15-2006, 03:58 AM
ages.
Distrubutor cap?
Jason.
Hi there i know what prob your having because i am having the same i really do think its my lamber thing i will keep you updated dont worry know one knew what i was going on about when trying to tell them the prob but i do know yours
Thanks Chris email me if you like chrisbrookuk@hotmail.co.uk
Ricochet74
03-15-2006, 09:37 PM
I have had almost the same problem since December. I have taken it back to the dealer 7 times now. Previously they have looked at several different probs and basically told me that all was ok. They have now told me that there have been other cars with the same problem. And they have now logged the problem with FORD. Dont know why this didnt happen after the second or third time!!!:banghead:
I was also advised that FORD really doesn't know what the problem is and that it may take another month for the service engineers to find a fix. I was also told that if this doesn't happen within a month, they may not be able to fix the problem at all. Not very happy about this.:crying:
ages.
Distrubutor cap?
Jason.
Google
Web AF
