95 start probs...
bill57
12-19-2005, 06:34 PM
I have a 95 Monte and i am having startting problems. it wont turn over wont even click or nothing. but with the key on i can jump it on the starter and get it to run perfect.. i searched and read all the prior start problem posts and i have put in a new starter...checked fusible links ...taken off all the tloom and checked the wires...re did all the connections cleaned em up etc..the key is not dmaged nor is the chip.i t is a tilt steer and i am to the point where i think it may be the wires in the steering wheel
****so i need to know how the heck to get the steering column cover off...i have the air bag out and the sterring wheel off now what?
and what do i look for once i get in there????
any other suggestions to check for the start prob?
thanks in advance for ne suggestions
CEO Wrench
12-19-2005, 08:12 PM
You don't need to take the steering wheel off to get at the ignition switch. It's located under the dash on the top of the steering column. There is a steel rod connecting it to the key cylinder.
bill57
12-21-2005, 05:39 PM
ok well i looked at that switch and all the wires and connections look good but theres like 10 wires going up by the keys how do i get the column cover off to check them and what exactly should i look for??
bill57
12-21-2005, 06:29 PM
ok so heres my progress i got to that ignition box and tested all the wires and there was a post with a yello wwire on it that had no volts until you turn the key over so i figured this was the starter wire so i ran a wire from this poost to the lil bolt on the starter and it fired right up...so do i just run my own new wire or where would the other one be bad?
CEO Wrench
12-22-2005, 08:09 AM
As for your question about the other wires going up the steering column, those are for the brake/turn signal switch, the wiper switch, cruise control, radio buttons, key chip, and dimmer.
Running a separate wire to the starter is certainly an option, and I'm not aware that there's anything significant you'd be bypassing. I ususally try to first figure out where the link has been severed first, though, as there could be a fusible link that has been blown, or there was wire chafing that could compromise the other wires. Try using a volt meter and a probe and isolate where that wire has lost continuity. Good luck!
