Windshield rust repairlaxman21 12-18-2005, 12:01 AM Well my windshield started to leak. Kept finding water on the carpet after a rain shower. Well, after having my windshield replace about 4 times, I started to notice rust around the gasket. I guess safelite didn't prime the area after removing all the broken glass. The guy who installed the new one after it fixed the rust said they were notorious for that practice. So, I decoded to fix it myself since none of the local shops would touch it. Tools needed: Windshield removal tool Rust removal tools, What ever you want. I used to following: Drill with various attachments. Angle grinder with wire wheel Dremel with various attachments Various sand paper grits Body filler POR-15 Rust Preventive Paint touch up paint I tried to remove the least amount of body part possible. Don't do it, remove them so you don't damage them. What I needed to remove: Hood Cowl Fenders http://img.photobucket.com/albums/v448/therealsundance/s-10truck006.jpg http://img.photobucket.com/albums/v448/therealsundance/s-10truck007.jpg I started by chipping all loose paint off. Next, I got down to business with the power tools and removed all the rust. I forgot to get pictures before I started and at this point. The surface was pretty pitted so I opted to go with the POR-15 with metal filler. I put plenty of coats on to fill in all the pitting. Now, I had only one small spot on the drives side pillar which I filled in with putty. http://img.photobucket.com/albums/v448/therealsundance/s-10truck012.jpg The other hole I had in the top area where the windshield caulk would be placed was filled in with the POR15. I should have used lead or body solder. But, I was unaware of that method at the time. http://img.photobucket.com/albums/v448/therealsundance/s-10truck011.jpg After POR15 was applied http://img.photobucket.com/albums/v448/therealsundance/s-10truck003.jpg OverBoardProject 12-18-2005, 01:07 AM Good for you! Good topic! I perfer using a sandblaster to clean the surface, but they do make a mess and you only want to use them close to the edges. But more important than that, you should paste this in the Blazer forum, FAQ sugestions box. It really belongs in in the frequently asked questions section, and the sugestion box is only in the blazer section Automotive Network, Inc., Copyright ©2012
