Originally Posted by gmc2003ZR2
2003 gmc sonoma ZR2 Highrider 4.3 vortec V6: I have searched threads and have not found any answers....lil help here
P0128 - Coolant Thermostat (Coolant Temp Below Thermostat Regulating Temperature)
I just added coolant to my zr2 and the temp is runing around 160+- when it usually runs @ 240+-.
Is it safe to drive if coolant resivior is full?
How do you clear this code?
Do I need a new Tstat?
Does it need to be cleared by a shop computer?
Is it hard to change, if you are mechaniacally inclined)
I just disconnected battery terminal and code did not clear.
any help is much appreciated!
Matt
Well you can ussually have auto zone erase a trouble code after they read it. When you added coolant did you purge the air out of the coolant system by running the engine up to normal operating temperature with the radiator cap off (some vehicles use a cap at another location in the coolant system for purging air) and make sure you have the heater on to purge air from the heater core.
You can also have a bad coolant temperature sensor, I am not sure where the sensor is on your engine but you should be getting a 5 volt reference to it, and maybe someone on here knows the resistance values it should read at specific temperatures, 160 sounds a lil cold maybe thermistat if the temperature is actually that cold, but 240 sounds a bit hot it may be a sensor
