| Off-Topic Talk about anything other than cars. |
12-16-2005, 01:26 PM
hit a curb, no tire movement Whats wrong now?!
k so i let my brother drive my car to work about a week ago in ice and snow, he decided to pull an ebrake turn and ended up hittin the front passenger tire agaisnt a curb. so far the damage that i know of from looking is the passenger cv axle is broken and the passenger controlling arm is broke as well. figured easy enough to fix. but anyways i went out there today to fire it up and let it idle for a bit cuse it hasnt been started in a while. then i put it into gear and let the clutch out to see if the drivers side tire would move. no movment what so ever on the dirver side tire. but the speedo says its doing leik 40 km/h but on the passenger side u can see that the part of the axle comin outta the tranny is movin when its in gear. beofore the accident i was aware that the car would need new cv axles on both sides. Could it be the tranny got nudged and broke somithing inside of it, or both cv axles broken? any would would be much apreciated. thanks!
1990 plymouth laser rs turbo, 5 speed, fwd, k&n filter boost gauge, pillar, paitned valve cover, magnaflow muffler.
12-16-2005, 01:31 PM
Re: hit a curb, no tire movement Whats wrong now?!
First mistake was letting your brother drive it in the snow and ice... Is it AWD or FWD? If its FWD then I'd say somethings broke in the tranny, if its AWD then I'd think more into the transfer case...
12-16-2005, 01:34 PM
uh oh... its front wheel drive...
12-16-2005, 01:52 PM
Well, I'm not 100% sure if its the axles or something inside the tranny... I'd inspect everything you can and see if anything else is cracked, split, or bent... It looks as if your gonna have to play some guessing games. Its just really hard to tell what it could be without seeing the extent of the damage and how the wheel actually hit the curb.
12-16-2005, 04:10 PM
It sounds like everything inside your tranny is working fine since the vss is driven directly off of the differential and if that didnt spin then your speedo would read 0. I would suggest first replacing what you know to be broken(cv's tie rods ect) and go from there becasue the last thing you want to do is buy a new tranny when you dont need one
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
12-16-2005, 04:42 PM
yah, i just talked to one of my friends and he was telling me something about it having a something differnential, open differential maybe? whitch would let just one wheel spin untill it grips or something. unless it has a limited slip differential in it. and since the cv axle is broken on the passenger side, it would just continue to spin. does this make sence?
12-16-2005, 05:09 PM
Holset powered 420a
yes, that most likely is the problem.
98 Eclipse GS Turbo
MSnS - Holset Wh1c Turbo - Je Pistons - Eagle rods - 60mm TB - ARP Headstuds - Turbonetics wastegate - 3" Turbo back - FMIC - Type s BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Prothane motor mounts - Zoom clutch - GSX Calipers - Oil Cooler - WBo2 - Devilsown meth injection
339whp 310wtq - 20g @ 23psi
12-16-2005, 08:01 PM
Yeah that definetly sound like the problem. When i wrecked my 90 eclipse the drivers side cv shaft was broken so i couldn't move the car at all.
ps you need to roundhouse kick your bro, or ask chuck to do it.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
12-17-2005, 12:28 AM
Jizzed In My Pants
Yeah I agree with them. How fast were you going into the curb?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
12-17-2005, 01:22 AM
Originally Posted by laser apexi turbo
k so i let my brother drive my car to work about a week ago in ice and snow, he decided to pull an ebrake turn...
Sure blame it on your "brother." jp.
12-17-2005, 08:08 PM
i dont really know how fast he was going, i think pretty slow, but he hit the curb with the tire parrallel to the sidewalk. id give u guys detailes but its way to long and hard to explain.
