oil additivezeek1403 12-16-2005, 09:42 AM I have a 1997 Corolla with 150K miles on it. It burns oil a bit and I bought some anti-engine leak stuff. Since the car only uses 3.6 quarts for an oil change, should I use only half of that additive instead of a full quart? joykill 12-17-2005, 01:45 AM depends...just how bad is your oil leaking??? zeek1403 12-17-2005, 07:35 AM I usually change the oil every 3-5K miles and it burns off around 2 quarts. joykill 12-21-2005, 10:44 PM its sounds if you got a leak that is a good candidate for a replacement of all the gaskets and seals in the engine...not really hard work but time consuming...and one think about stop leaks...dont use them...rarely work and they can also mess things up more than it was before... Automotive Network, Inc., Copyright ©2012
