Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > GMC > Sierra
Old 12-15-2005, 08:31 AM   #1
swensonb71
swensonb71 Normal reputation
Send a message via Yahoo to swensonb71
Question no 6 cylinder misfire
i have a 96 gmc z71 that idles and starts fine. as you use about 1/4 throttle or put it under a slight incline requireing more power the code for #6 cylinder code pops up and sometimes a multiple misfire code pops up if i mash the gas pedal. i noticed when i did mash the gas with my scanner hooked up that the timing woudl retard itself to accomidate fuel to rich ( i think). any ideas?
also does anyone know about a scanner that would dispaly the cam position sensor info that has the capability to reset the sensor without going to the dealership?
swensonb71 is offline   Reply With Quote
Old 12-23-2005, 07:50 PM   #2
LastOne
LastOne Normal reputation
Try swapping the spark plug and wire with 7, the wire should be close enough to reach. Also could be carbon buildup on the valves. Try some Seafoam in the intake. Suck it in via the vac hose off the brake booster.
On my 5.7 it was mechanical sticking in the heads, I switched to full synthetic oil and after about 2500 miles it was cured.
LastOne is offline   Reply With Quote
Bookmarks
Google
Web AF
