BCM fuse locationJRN_WIS 12-13-2005, 11:57 PM I've searched many variations of BCM and fuse, etc. and struck out Can someone please explain where to find the fuse that will reset the BCM in a 1992 Grand Caravan? There is no reference to the 10D fuse in the manual or Haynes book. Thanks earlyrizr 12-15-2005, 01:08 AM it's iod (ignition off draw) if that will help.I just disconnect the negative cable then the positive cable to the battery and then connect them(both cables) together for 10-15 min,during this time I will also clean the terminals on the battery.this will reset the bcm aswell.might work for you Automotive Network, Inc., Copyright ©2012
