Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 12-13-2005, 01:53 PM   #1
JohnnyK101
JohnnyK101 Normal reputation
Unhappy 94 astro won't start in the morning
Hi, I have a 94 astro, and every morning it won't start. Turns over good, sputters and tries to fire off. If I keep trying it finally starts, but it is getting worse. Changed fuel filter, no help. I get no lights / codes. After the hard start in the morning, it runs fine.
Any ideas?
thanks, John
JohnnyK101 is offline   Reply With Quote
Old 12-14-2005, 10:27 AM   #2
drew300
drew300 Normal reputation
Re: 94 astro won'tstart in the morning
My '97 did the same.
Have you checked the fuel pressure? I don't know what a '94 should be. My pressure was down a few lbs, it was very difficult to start, but with a shot of starting fluid, it started up just fine, and kept running, with easy restarts that day. Next day, same thing. I replaced the pumps, and all is well. At least your pump should be cheaper. (lower pressure system).
drew300 is offline   Reply With Quote
Old 12-14-2005, 05:24 PM   #3
madness67203
madness67203 Normal reputation
needs a fuel pump, and pulsator. Just went through all that on my 96. The fuel in the tank helps keep the pump cool. When gas prices were at an all time high, I ran it on about a 1/4 tank all the time. When I took the old pump out the connector on the pump itself was melted. The carter pump comes with new wires and connectors.
madness67203 is offline   Reply With Quote
Old 12-15-2005, 09:27 AM   #4
drew300
What is this "pulsator" I've heard about. When I replaced the "fuel pump assembly" I didn't see anything odd. Also, on mine('97), the pump is housed in a well, which is kept full by the fuel return line. It appears my pump would have gasoline coolant even when the tank ran dry. The replacement was Carter.
Bookmarks
Google
Web AF
