Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > Taurus/Taurus Wagon
Old 12-13-2005, 12:08 AM   #1
monte85
monte85 Normal reputation
Question 97 taurus tranny problem (help)
i have a 97 taurus 3.0 that ran great until last week! for some reason the tranny wont shift up from 2nd and the speedometerdoe not work only happens when its cold once it gets to normal operation everything works great.i got code 0500 speed sensor fault so i bought it no luck i changed the fluid and filter.still no dice any help will do
monte85 is offline   Reply With Quote
Old 07-15-2006, 11:11 PM   #2
taurusdude06
taurusdude06 Normal reputation
Send a message via MSN to taurusdude06 Send a message via Yahoo to taurusdude06
Re: 97 taurus tranny problem (help)
Still having problems, and do you want to get rid of it??????
taurusdude06 is offline   Reply With Quote
Old 07-16-2006, 06:28 AM   #3
Huney1
Huney1 Normal reputation
How many miles are on it and has the ATF ever been 'flushed?' You 'changed' the ATF which replaced about 6 qts, but it holds about 16 qts and you left 10 old qts in the torque converter. The only way to completely get all the old ATF out is with a 'flush' and it takes a special flushing machine to do it. If the valve body gets dirty it can cause shifting problems so when you get it flushed have it cleaned.
Replacing the speed sensor was a good call and I think the speedo works off that sensor to.
Huney1 is offline   Reply With Quote
Bookmarks
Google
Web AF
