oil leaksubparcar01 12-12-2005, 11:46 PM i have a 96 dodge neon with automatic trans and high miles w/oilleakand was wondering if anyone out there would have a solution/advice. it is leaking from above the oil filter but not from the filter could it be the c/v joint, timing case..? das2123 12-13-2005, 08:38 AM Sounds like your Rear main seal. Not an easy replacement but is doable. claudius 01-25-2006, 09:07 PM If ur not done yet, its the oil pressure sensor just above the oil filter that is leaking trough its connector. Replace it. Automotive Network, Inc., Copyright ©2012
