Can someone please explain what the problem with my car is? Recently (within the past month) my car has begun to shake. It shakes when Im in drive neutral - everything but park. It is happening more frequently recently and Im nervous as to what it is. My dad said he thinks it might be the lifter, but I wanted a few opinions. The car has oil (actually has been suffering from an oil leak recently as well). I do not have time to take it to the mechanic this week or next. The sound is not a loud sound but more of a knocking movement of the car instead. If there is anything anyone can suggest I would really appreciate it.
Is your check engine light on? If so, do the key dance and read thew codes. If you don't know what the "key dance" is, do a search on this forum and you should find it. How are your RPM's? Do they jump around at idle?
my check engine light was on a while ago- i think it was due to low oil, i was about to get it checked out and it turned off and hasnt gone back on. The RPMs done seem to be a problem when Im idle. its below 1,000 it doesnt jump or anything
